It is currently Mon Nov 02, 2026 1:48 pm
Post subject: Punte de Uaz pe Aro Posted: Fri May 07, 2010 8:37 pm |
Post subject: Din nou la munca... Posted: Fri May 07, 2010 8:39 pm |
Post subject: Re: Din nou la munca... Posted: Fri May 07, 2010 8:41 pm |
Post subject: Re: Din nou la munca... Posted: Fri May 07, 2010 9:09 pm |
Felicitari Cab,a iesit faina doar ca e putin cam inalta,cred ca ar trebui sa renunti la body lift sau sa scoti o foaie doua dar din cele scurte.
Post subject: Re: Din nou la munca... Posted: Fri May 07, 2010 9:16 pm |
Post subject: Re: Din nou la munca... Posted: Sat May 08, 2010 1:41 pm |
Daca ai rapoarte bune, in jur de 5 e ok,ar fi solutia ideala si ar arata bestial
Post subject: Re: Din nou la munca... Posted: Sat May 08, 2010 3:55 pm |
Revin cu parerea mea exprimata anterior.
cu rapoartele de 5.12 baga 35"uri pe ea si o sa mergi lejer.
Post subject: Re: Din nou la munca... Posted: Sat May 08, 2010 8:23 pm |
33 urile au 83 cm diametru iar 35 -88cm,vezi care intra mai bine.
Post subject: Re: Din nou la munca... Posted: Sat May 08, 2010 9:29 pm |
Post subject: Re: Din nou la munca... Posted: Sat May 08, 2010 9:34 pm |
Uauu,pai astea sint de combina  Crezi ca incap ?
