It is currently Sun Nov 01, 2026 2:47 pm
 Post subject: Cutiile de viteza/transfer 24x/32x
PostPosted: Wed Sep 09, 2009 11:15 am
ARO L25
Cutie de viteze: ARO, sincronizata, 4+1 trepte
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
Cutie de transfer: ARO, nesincronizata, reductor si distributie prin pinioane, 2 trepte
H - 1.0000
L - 2.1267
4x2 spate / 4x4
ARO L30
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
ARO L27
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
ARO D127 "BRASOV"
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
ARO DX28
Cutie de viteze: ARO, sincronizata, 4+1 trepte (5+1 trepte)
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
ARO TDX28/TDX28.02
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
Andoria 4C-90
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
Andoria 4CT-90
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
 Post subject: Re: Cutiile de viteza/transfer
PostPosted: Wed Sep 09, 2009 11:21 am
Peugeot XD3-P
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
Cutie de viteze: Peugeot, sincronizata, 5+1 trepte
1 - 4.0320
2 - 2.3934
3 - 1.5212
4 - 1.0000
5 - 0.7812
R - 3.7600
H - 1.0000
L - 2.1267
4x2 spate / 4x4
Peugeot XD3-TP
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
5 - 0.8380
R - 4.7948
1 - 4.0320
2 - 2.3934
3 - 1.5212
4 - 1.0000
5 - 0.7812
R - 3.7600
H - 1.0000
L - 2.1267
4x2 spate / 4x4
Toyota 2L-T
Cutie de viteze: Toyota, sincronizata, 5+1 trepte
1 - 3.9540
2 - 2.1410
3 - 1.3840
4 - 1.0000
5 - 0.8500
R - 4.0910
Cutie de transfer: Toyota, reductor planetar si distributie prin lant, 2 trepte
H - 1.0000
L - 2.6500
4x2 spate / 4x4
Toyota 2RZ-FE
1 - 3.9540
2 - 2.1410
3 - 1.3840
4 - 1.0000
5 - 0.8500
R - 4.0910
H - 1.0000
L - 2.6500
4x2 spate / 4x4
Chrysler 205HX07
Cutie de viteze: Chrysler, sincronizata, 5+1 trepte
1 - 3.9300
2 - 2.3300
3 - 1.4500
4 - 1.0000
5 - 0.7500
R - 3.7500
Cutie de transfer: Chrysler (New-Process), reductor planetar si distributie prin lant,, 2 trepte
H - 1.0000
L - 2.7200
4x2 spate / 4x4
Ford Cosworth BRG
Cutie de viteze: Mazda M5OD - R1 , sincronizata, 5+1 trepte
1 - 3.4010
2 - 2.0480
3 - 1.3120
4 - 1.0000
5 - 0.7910
R - 3.4920
Cutie de transfer: Borg-Warner, reductor si distributie prin pinioane, 2 trepte
H - 1.0000
L - 2.4800
4x2 spate / 4x4
PostPosted: Wed Sep 09, 2009 11:23 am
VM 06B
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
Perkins 4PA203
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
VAMO UMZ-8290
1 - 4.6440
2 - 2.5310
3 - 1.5610
4 - 1.0000
R - 4.7948
H - 1.0000
L - 2.1267
4x2 spate / 4x4
 Post subject: Re: Cutiile de viteza/transfer 24x/32x
PostPosted: Thu Nov 05, 2009 2:52 pm
Ford Vulcan (Crosslander)
1 - 3.4010
2 - 2.0480
3 - 1.3120
4 - 1.0000
5 - 0.7910
R - 3.4920
Cutie de viteze: Ford A4LD-4R44E/ 4R55E , automata 4 trepte
Ford Cologne 2.9 (Crosslander)
1 - 3.4010
2 - 2.0480
3 - 1.3120
4 - 1.0000
5 - 0.7910
R - 3.4920
Ford Cologne 4.0 (Crosslander)
1 - 3.4010
2 - 2.0480
3 - 1.3120
4 - 1.0000
5 - 0.7910
R - 3.4920
PostPosted: Thu Feb 03, 2011 6:22 am
Hi All Team!
Whether who have photos or drawings ARO 24-series with 5-speed gearbox, from down, from different angles and points?
I would like to see, how it was placed on a frame. Whether the serious changes in a design of a frame were spent or 5-speed gearbox it is possible to mount on any frame?
All variants are interesting to me, and ARO, and EATON, but especially PEUGEOT and TOYOTA (2 LT engine + gearbox).
Photos maybe to send on my e-mail or placing in this theme...
Beforehand I thank for Yours answers!
...in me tries to be born an idea...
PostPosted: Thu Feb 03, 2011 3:23 pm
There is no major change in the design of the frame. Most of the 5 speed gear boxes that were fitted on ARO are longer than de 4 speed original 'box, so the solution was to mount a cross beam, a simple rectangular bar situated at the rear of the transfer case, underneath it, to support the gearbox and the transfer box. I think a should have some pictures at home, I will post them later.
PostPosted: Thu Feb 03, 2011 4:35 pm
You stand corrected, my friend.
Premises: We're only considering Romanian Engines - L25/L30/L27/DX28/TDX/D127
Fact: There are 5 possible models of 5-speed gearboxes which fit, to the best of my current knowledge
1. First version - they took the 4 speed gearbox, added an extension, and then the transfer case. It's basically a 4 + 1 type. Not very reliable or practical, I wouldn't personally use this. Naturally, longer than the 4-speed-box.
2. Second version - they redesigned the aluminum housing, to make it a dedicated 5 speed gearbox. These aren't particularly great either, and I wouldn't bother. Longer than the 4 speed box, not sure compared to the one above though.
3. Second version - Borg Warner gears and syncros - Same as #2, but with quality parts - very good, but not many were made. This should be worth it, but harder to find, and more expensive. Same as #2 length-wise
4. "Sfantu Gheorghe" box - A completely different box, designed by a private company, not ARO Campulung. Because this company didn't have the technology to cast aluminum, they used a hard-iron casing (same as the Brasov Engine Block). However the parts inside were very good (although locally produced) so this is a very sturdy, reliable and strong box - albeit a bit heavy. For this reason, they added a supplemental cross-beam to support the gearbox - easy to do it yourself - and it's the only Romanian made box which has this beam. It's just 30mm longer than the standard 4-speed box, so it's basically safe to use, with no other mods (except for the support beam)
5. Eaton box - Consists of two aluminum halves mated longitudinally by rivets. Reliable, though not exceptionally strong. (I'd rather abuse a 4-speed-box).
Bon apetit!
PostPosted: Thu Feb 10, 2011 11:53 am
Thanks Stefan!
It is the more interesting information! ...
But, me very much interests - AS, IT IS LOCATED ON A FRAME of 24-series???
I have measured ALL accessible transmissions! They are not located on frame 24! The central cross-beam of a frame is prevents!!!
Therefore, who can, give a photo from down, available for You (ARO, PEUGEOT, EATON, TOYOTA) of variants, of application 5 speeds, on chassy 24. Please!
I want to know, as, it did!
Very much it would be desirable to set a similar question for Dan Chiriac, about TOYOTA, but...
PostPosted: Thu Feb 10, 2011 2:20 pm
I don't have pictures at hand, but will try to assemble some.
Basically, all the Romanian boxes are just very slightly longer than the standard 4-box, and not at all wider. This is why they don't have any other support beam, or they don't "hit" the central cross beam you're referring to.
Otherwise said, the frame is 100% the same, and the clutch "casing" as well. Just the SfantuGheorghe cast-iron box is heavy, so it needs an additional support beam underneath it.
The Toyota box is the same as LJ70, and it won't fit other engines. It is however longer - just how much longer I'm not sure, nor do I know any other mods to the chassis - though I can imagine there are some.
PostPosted: Thu Feb 10, 2011 5:39 pm
I now check on suitability three variants transmissions:
1. From TOYOTA HiLux/Surf, part time.
2. From NISSAN PATROL GR 60, part time.
3. From JEEP WRANGLER/Cheroke (tr.box NV 242), full time.
But they very "long". :? A problem - average cross-beam of a frame. :(
