Termostat si sonde apa (D127)
http://www.offroadclubaro.com/viewtopic.php?f=20&t=564
Page 1 of 2
Author:  ama27 [ Tue Jul 12, 2011 10:18 pm ]
Post subject:  Termostat si sonde apa (D127)
Poze cu termostatul si cu sondele de apa
Author:  ama27 [ Tue Jul 12, 2011 10:21 pm ]
Post subject:  Re: Termostat si sonde apa (D127)
Fluierul de apa si pozitia termostatului
Author:  ama27 [ Tue Jul 12, 2011 10:26 pm ]
Sonda pentru becul de fierbere a apei - 5530 si e marcat cu 120 grade C
Sonda pentru indicarea temperaturii - are cilindrul care sta in apa mai mic
File comment: sonda temperatura
File comment: sonda bec
Author:  maxim [ Wed Jul 13, 2011 4:07 pm ]
thermostat analog:
WAHLER 4174.82D
FIAT 5 0032 9622
IVECO 50 032 9622
PEUGEOT 1338 90
Gates TH22782G1
Valeo 820 432
Febi 21003
Triscan 8620 5488
SWAG 62 92 1003
Facet 7.8314
Facet 7.8677
Quinton Hazell QTH558
Vernet 6581.82/J
HL Group Oy 500-120482
Behr B.346.83
Valeo 820 432
Author:  cabestan [ Wed Jul 13, 2011 4:19 pm ]
Maxim, do you know what car this fits?
Author:  maxim [ Wed Jul 13, 2011 4:32 pm ]
Hi Stef!
Yes. I'm fitting WAHLER 4174.82D on my 244.
All other - analogue for it.
p.s. analogue for temp sensor - not found :(
it's marked 5521
Author:  cabestan [ Wed Jul 13, 2011 5:29 pm ]
No no, I'm asking, what is the car that this thermostat was produced for? Was it made especially for ARO, or for a japanese car? If so, which?
Author:  maxim [ Wed Jul 13, 2011 6:44 pm ]
This is a very large number of ...
I try to give the most extended ones:
CITROEN JUMPER 230/230P/244 RELAY/RELAY II 2.8 HDi 128HP
FIAT DUCATO 2.8 HDi
PEUGEOT BOXER 2.8 HDi
i.e. all with IVECO 8140.43S engine.
Also:
IVECO Daily I, Daily II, with engines:
XY8, 149 A2.000; 149 A4.000, 8144.61, 156 C.046, 138 C2.048; 149 C1.000, 146 C3.000, 831 A2.000; 831 B.000, 831 D1.000,
ALFA ROMEO AR 6 (280) 2.4 TD [8144.21.220] 92 HP
OPEL Movano 2.5 D [S8U 770] 80 HP
SEAT 131 2.4 Diesel [8144.61] 72 HP
Also:
for all engines FIAT/IVECO/OHM 80-series, ex. - FIAT 8035.04, 8040.01, etc...
Also:
for SOFIM engines...
Author:  cabestan [ Wed Mar 28, 2012 10:38 am ]
Following Maxim's example - I ordered :
http://www.autoeco.ro/piese-auto/FIAT/D ... t-1625833/
WAHLER = 45 RON (VAT included)
Opening temperature = 82 deg Celsius - which I find to be a very good temperature for BV, compared to the Romanian variants of 83 / 85 deg.
Author:  KAROLOKW [ Thu Mar 29, 2012 1:19 pm ]
cred ca sonda aia de temperatura o am eu da trebuie sa verific prin cutia de suruburi
