It is currently Tue Nov 03, 2026 8:19 am
 Page 1 of 1 [ 7 posts ]
 Post subject: Aro 244 Power steering, servodirectie
PostPosted: Tue Jul 24, 2012 11:22 pm
Welcome. What Car suits from steam irons and power steering pump to the Aro 244 1986 D-127 engine?
Bine ai venit. Ceea ce se potriveşte de autoturisme din fiare de abur şi de pompe de alimentare de direcţie la Aro 244 1986 D-127 motor?
 Post subject: Re: Aro 244 Power steering, servodirectie
PostPosted: Wed Jul 25, 2012 1:13 am
Hi there,
You can adapt pretty much anything, various people have done so with varying success.
For the power steering pump the best suggestion would be Mercedes Benz w123 pump. It's mounted on a pulley, driven by a belt. The advantages are top reliability and very good pressure. Also, you have the steering fluid reservoir built-in.
For the power steering box there are several options. BMW 525 (older gen) would be one of them. I think Toyota LJ70 would also fit.
PostPosted: Wed Jul 25, 2012 6:55 am
see fitting pump from toyota:
viewtopic.php?f=14&t=251
and pump from MMC, from 4G63 engine:
http://www.aro4x4.net/smf/viewtopic.php?f=33&t=3460
PostPosted: Thu Jul 26, 2012 9:34 pm
A steering gear of a Mercedes W123 will be good? not for the weak? Sory to write in this topic.
PostPosted: Thu Jul 26, 2012 11:03 pm
If you can adapt it, then sure - it's strong enough.....
PostPosted: Fri Jul 27, 2012 8:27 am
PostPosted: Sun Jul 29, 2012 8:19 pm
That could be interesting! :lol:
I got 'stuck' on how great it would fit the TV, and forgot about this issue...
