It is currently Thu Sep 10, 2026 3:56 am
Post subject: Lubrifianti ARO 24x Posted: Thu Nov 05, 2009 12:55 am |
Ulei motor : 8 L (D127) - Speciticatii generale: Mineral, cat mai vascos la cald. Havoline Premium 20W-50 Havoline Texaco mineral de tractoare 15W-40 Lubrifin M40 / MD40 Prista Oil 15W-40 Se recomanda folosire unui ulei mai gros vara si daca este uzat motorul
L25/TDX 28 M20W/20 iarna M30 vara
Lichid Racire: 15 L (D127) 13,2 L (L25, L27, Tdx)
Cutie viteza (4 viteze ARO) 2.5 L T 90 EP 2 Petrom GEAR OIL SAE 80W-90 EP5 Petrom GEAR OIL SAE 90 EP2 Multigear 80W-90 Geartex EP-B SAE 85W-90 Valvoline HP GL-5 80W-90
Cutie transfer 1.5 L T 90 EP 2 Petrom GEAR OIL SAE 80W-90 EP5 Petrom GEAR OIL SAE 90 EP2 Multigear 80W-90 Geartex EP-B SAE 85W-90 Valvoline HP GL-5 80W-90
Grup Spate 1.7 L T 90 EP 2 Petrom GEAR OIL SAE 80W-90 EP5 Petrom GEAR OIL SAE 90 EP2 Multigear 80W-90 Geartex EP-B SAE 85W-90 Valvoline HP GL-5 80W-90
Grup Fata 1L T 90 EP 2 Petrom GEAR OIL SAE 80W-90 EP5 Petrom GEAR OIL SAE 90 EP2 Multigear 80W-90 Geartex EP-B SAE 85W-90 Valvoline HP GL-5 80W-90
Lichid Frana 0.75 Tip N Dot 3
Servodirectie 3L Texamatic 1585 Petrom TRANSMISSION FLUID ATF D II TA 32
Post subject: Re: Lubrifianti ARO 24x Posted: Thu Nov 05, 2009 12:06 pm |
Motor Peugeot XD3TP 2.5 TD 6 litri
Daca motorul e in stare buna sub 100.000km > Ulei 10W40 pt turbodiesel motor mai uzat >100.000km > Ulei 15W40
Post subject: Re: Lubrifianti ARO 24x Posted: Sun Nov 08, 2009 12:20 am |
Pt cele turbo diesel, trecute de 100.000 km recomand Castrol Magnatec 15W/40. Eu numai din asta pun de ceva timp si pare foarte ok... pana acuma...
