It is currently Sat Oct 31, 2026 11:20 pm
 Page 1 of 1 [ 3 posts ]
 Post subject: Garnituri frane
PostPosted: Fri Mar 16, 2012 1:37 pm
Cilindri frana :
30mm
Set reparatie cilindru receptor frana ARO 240-244, AUTOFREN SEINSA D3199
Producator: AUTOFREN SEINSA
Cod producator: D3199
Partea de montare: punte fata, puntea spate
Diametru [mm]: 30
28,6mm
Set reparatie cilindru receptor frana ARO 240-244, AUTOFREN SEINSA D3036
Cod producator: D3036
Diametru [mm]: 28,6
Sistem frânare: LUCAS
25,4mm
Set reparatie cilindru receptor frana ARO 240-244, AUTOFREN SEINSA D3035
Cod producator: D3035
Partea de montare: puntea spate
Diametru [mm]: 25,4
Ambreiaj :
Set reparatie, cilindru receptor ambreiaj AUTOFREN SEINSA D3210
Diametru [mm]: 30
Pompa Frana :
AUTOFREN SEINSA D1185
Set reparatie, pompa centrala frana - probabil pompa simplu circuit, Diametrul se potriveste cu pompa de ambreiaj
R: 25,4 mm
FRENKIT 125001
Set reparatie, pompa centrala frana * idem, diametru pentru pompa de ambreiaj
R: 25,4 mm
FRENKIT 127002
Set reparatie, pompa centrala frana - pompa dublu circuit
R: 27 mm
Sistem franare: Lucas
 Post subject: Re: Garnituri frane
PostPosted: Sat Mar 17, 2012 5:16 pm
Am masurat o pompa de ambreiaj de BV si are 25mm, iar pompa de frana are 27mm (cred, asta n-am putut s-o desfac)
PostPosted: Mon Mar 25, 2013 1:21 pm
Set reparatie pompa frana (simplu circuit) / pompa ambreiaj ARO 240-244, AUTOFREN SEINSA D1039
Cod producator: D1039
Diametru [mm]: 25,4
Pret: 22 RON.
