It is currently Fri Oct 30, 2026 3:33 pm
maxim
Post subject: ARO243, MAXIM Posted: Sat Nov 07, 2009 6:54 am |
To presentation of it's the car is not necessary. Many a remember her from AROClub Romania. But, in two words: 243, 1991 year, powered BRASOV D127005, 4st gearbox, full drums brake system. Run, now, approximately 410000km. Living - big city 60%, village 20%, hard offroad 20%. The most distant travel - 2000km, in one side. The most capacity 13 men. Working temperatures up -38C to +36C (really) Repaires : engine: in 1993 y - BRASOV, was change the piston rings, the injection pump, the injectors; in winter 2002-2003 - was change the injection pump, on VE BOSCH type, handmade and nozzles (DTP 11199); in summer 2008 - was change engine on "new BRASOV". transmission: in1996-1998 3 times was change the rear conic group; 2008 - was change all bearings and sealings in transfer box and all gearbox sealings; by necessity - other bearings and sealings. Illness - often damaged of the frontal driving shafts.
Brakes and clutch: in 2000 - was change the master brake cylinder (15/16', free outs, from MMC pajero); in 2002 all clutch cylinders (KIA GRACE/DAEWOO ISTANA); by necessity - changed the wheels brake cylinder sealings and the brake shoes. in1997 and 2008 thrust bearing; in 2008 - clutch disc
Body: in 2000 - big war against corrosion and bodylift 2' . in 2001 - was change the windscreen (made by order). Last ten years - Infinite changing of the salon interior...
Post subject: Re: ARO243, MAXIM Posted: Sat Nov 07, 2009 9:09 am |
Nice to see Brasov in Russia
maxim
Post subject: Re: ARO243, MAXIM Posted: Tue Mar 30, 2010 3:44 am |
nelutzu
Post subject: Re: ARO243, MAXIM Posted: Tue Apr 06, 2010 11:57 pm |
maxim
Post subject: Re: ARO243, MAXIM Posted: Thu Apr 08, 2010 5:06 pm |
Hi Nelutzu! Front mask - all handmade. Headlights - VOLGA 3102, flashers - four from LADA (VAZ 2101 / FIAT 124)
maxim
Post subject: Re: ARO243, MAXIM Posted: Tue Aug 31, 2010 7:11 pm |
Post subject: Re: ARO243, MAXIM Posted: Tue Aug 31, 2010 11:00 pm |
Plastec
Post subject: Re: ARO243, MAXIM Posted: Wed Sep 01, 2010 1:34 pm |
cred ca se refera la faptul ca ultima spira de la arc este rupta
nelutzu
Post subject: Re: ARO243, MAXIM Posted: Wed Sep 08, 2010 10:54 pm |
