It is currently Wed Sep 09, 2026 9:31 am
scaniaxxs
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Fri Jan 04, 2013 6:47 pm |
Astazi am verificat prin vizionare la fata locului,si dupa cum ti-am spus galeria de admisie din tabla de otel se monteaza fara distantieri ,dar oricum trebuie modificata pentru a avea loc mecanismul pompei de injectie.
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Wed Feb 13, 2013 4:38 pm |
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Wed Feb 13, 2013 4:46 pm |
arcasul
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Mon May 27, 2013 6:10 pm |
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Mon May 27, 2013 6:13 pm |
arcasul
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Mon May 27, 2013 6:20 pm |
scaniaxxs
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Thu May 30, 2013 11:17 am |
Salut.Pompa respectiva eu am luat de pe lancia prisma motor 1,9 td dar merge si de lancia prisma 1,9d motor fara turbo.[acelasi cod dar cu 44 la sfirsit].
scaniaxxs
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Sat Oct 12, 2013 8:20 am |
Ieri am achizitionat o pompa de injectie VE-L 269 ,asa ca am sa-l rog pe colegul CAB512 sa ma ajute si pe mine cu o poza sau o schita a pinionului pompei dacalat.Multumesc anticipat.
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Fri Oct 18, 2013 8:10 pm |
Cristi Dan
Post subject: Re: Schimbat Pompa injectie/alimentare D127 "Brasov" Posted: Tue Oct 11, 2016 7:52 am |
Va salut baietii!
M-a lasat pompa de injectie pe aroul meu si vreau sa pun si eu ceva mai de calitate...am tot cautat pompa de Alfa,dar nu am gasit pe niciunde una fara electronica...poate stiti voi una pe undeva...daca ma puteti ajuta as fi recunoscator...
Cu respect, Cristi Dan
